I think there is a little more to it than just taking your stuff on and puting in a d60. I ain't no expert on this but there may be a few things to change
It's a direct swap. Brake lines will be different and you'll have to modify is the trab bar mount bolt on the passanger side. You'll have to grind it down or it will hit the pan. I didn't bother installing the sway bar and never had an issue.
