purpleheart350
Ok so I hooked up a scan gauge to my truck today and got all these codes (8) and need help figuring out what I need to do to fix them
P0196 Engine Oil Temperature Sensor Range/Performance
P0236 Turbo Boost Sensor A Circuit Performance
P0267 Injector Circuit Low - Cylinder 3
P0284 Cylinder 8 Contribution/Balance Fault
P0344 Camshaft Position Sensor Circuit Intermittent (bank1/1 Sensor)
P1212 ICP Voltage Not at Expected Level
P1271 High to Low Side Open - Cylinder 1
P1277 High to Low Side Open - Cylinder 7
I also got these numbers just in case they are needed
ICP DC% 12.8
ICP PSI 625-700
Injector pw/ms .9-1.3
ICP DC% 12.8
ICP PSI 625-700
