purpleheart350
Ok so the back story to it is about a month ago the fan and clutch assembely came off and blew through the radiator. I didn't find that out till I got to work and was pissing fluid, and engine temp light came on. Got it home, new radiator and electric fan went in. Truck actually runs cooler with e-fan. Well I have ha a little leakin since then and at first thought it was fluid just left over from the swap. Not the case since not I am leaving antifreeze fluid everywhere I go.
Well now I have narrowed it down to the water pump area. So now is where I need the input. Should I replace the gasket to see it that will fix it ( $10 tops and a few hours) or replace the whole pump. I will also be replacing the tstat.
