97 ipr and fpr questions
MossBack
UTAH
So last night I decided it would be a good night to replace the o-rings I bought on my truck.
Well after a hour everything was out and going back together and all seemed well. I did however found the wires melted together for the ipr. I assumed that was from last year when I had a no start issue and unplugged heater.
So I decided to cut out the bad wiring and figured it had to run as it did b4.
so now no start I filled the bowl up. Checked multiple times and I even cracked the lines at the front of the head. It cranks good and I have got it to run at about 500 rpm and ran it a little on ether with gp disconnected. My question is the ipr going to not let it run or did I maybe do something to the fpr? It seems to turn over a little bit if I remove the filter and suck out some fuel but then it just makes a mess. Thanks foe input I will be able to figure it out I m starting with a new pigtail for the ipr. But it seems like the fuel gets trapped and won't return which leads me to fuel.
Sent from my PC36100 using Tapatalk
MossBack
UTAH
fixed it the IPR does need to be plugged in. lesson learned do not over complicate a small issue.
