Keep in mind guys AC systems are pretty simple systems. (I found this online as to save me from typing it out) There could be lots of causes. I'll run through a few common ones.
1. The air conditioner compressor is broken - to fix it you'll need a new compressor, schrader valve, and possibly the evaporator.
2. The belt isn't on the compressor or isn't tight enough - to fix it, you'll just need the belt and have it properly tightened.
3. The freon has leaked out of the system - to fix it, you'll need to find the leak, repair it (could be a hose or the condensor, thest two are the most likely, but not the only places that could leak.) Then you'll have to have a vacuum pulled on the system and new freon.
4. The low pressure cut off switch is broken - just a new low pressure cutoff switch and a freon re charge.
5. Relay could be out - just a new relay.
6. The AC switch could be broken - just install a new switch will fix it.
Most of these repairs will have to be made at a shop with an A/c system handy to remove/recharge the sytem
