A couple of FICM/Injector Questions.....
Silver6
S. Carolina
newbie here, long time lurker, first time poster. Very appreciative of all the info I have already gotten from the site without even being a member. Now, Ive got a couple of issues. Short story on my truck is:
06 250 CC SB
studs and all small engine "upgrades" done first of the year
s&b intake, 5" straight exhaust, gauges, SCT innovative tunes
FF to now. Last week the truck started running terribly rough and blowing a considerable cloud of smoke upon cranking. This was during the day and warm. (98*+ outside) Got worse, checked codes, and 2 injector failures. Tried to limp it to our shop, and it died on me. Called Jess Warren and had him overnight me 8 190/75 injectors. Got those in, but now it is bucking terribly (especially when cold starting) Will take several, several miles to start running decent, but never runs great. Also, has a lope at idle, meaning it will bounce between 250rpms. Sounds cool, but its obviously not what I want. Also, the truck has been doing this for awhile: cold starting, even in the crazy hot temps we have had, it is rough starting, and blowing a slight haze of whiteish smoke out the pipe. From all the research I can find, everything points to ficm. ? Waitiing right now on the engine to cool down to test it, but would like any other opinions on what I should look for in case it tests out good. Also, just did a service on the truck, oil and fuel filters. And, the only code I get now with the lope and rough start/running is p0263 - cyclinder #1 contribution/balance. TIA guys.
Silver6
S. Carolina
just tested the ficm. solid 48 with the key on, dipped to 31 while cranking, but went straight back to 48 when started. Anyone?????
Silver6
S. Carolina
ok, got a 58v ficm from innovative. Put it in last night and truck was running a lot better, but still not perfect. This morning still blew a haze upon crank and warm up. Had to pull our bobcat back to shop from a job, and things went south. Chattering bad again like injectors, next redlight I fogged out everyone with a cloud of white/greyish smoke, then the trucks power went in the tank. Pulled off, shut it down, tried to restart it, locked up. Talked to jesse and he said no doubt injector o-rings. Last night the code was #1 cylinder balance/contribution, now its showing for #3, and the #1 code is nowhere to be found..........starting to hate this truck......
bboteler
Virginia
Injector o-rings but def need to get that ficm fixed...I agree with the above check the harness they can be a pita!
