a little ac help please
diesel dane
Nashville, TN
A little ac help. ok guys. I'm almost wrapped up with the 97OBS. running great. but recently the ac stopped working. We aren't getting 12 v to the compressor and we checked all the fittings under the hood to track down maybe a short with the volt meter. No luck. Im thinking the problem is the AC switch in the cab. maybe something happened during the painting of all interior black.
Does anyone have a wiring diagram for the ac controls in the cab to diagnose if it is the switch or not? We can get the clutch on the compressor to move with a jumper from the battery so we can rule that out. it still blows hard. Just not cold.
Thanks in advance. :fordoval:
zilla68
Moore Oklahoma
did all your plugs get put back on right on the back of the controls?
sorry, I misread you said no power to compressor, I was thinking if its blowing hard and not coming out maybe the blend door was stuck.
fuses and relays good?
I can look at home, I might have the info in my book I ordered online.
diesel dane
Nashville, TN
All plugs are in. I want to check voltage at the switch so I can determine if it's that or a short down stream. Anyone with a wiring diagram for Ac switch?
Jake
TEXAS
I don't have the wiring diagram, but it basically goes from the dash switch, through the low pressure switch, then high pressure switch, then to the clutch.
Try jumpering out each of the switches to see if that does it. The high pressure switch have given me crap on every truck I've owned.
Philips97
Sounds like you might be low on refrigerant if you jump it out, but blows warm air. Low pressure switch is probably keeping the compressor from coming on and tearing it up.
diesel dane
Nashville, TN
Now we're thinking. It's a possibility. The truck sat for a few years during the build. It didn't get charged as far as I know. That said, It was ice cold and then nothing leading me to think electrical. Luckily the truck pretty much only gets driven fast in the evening when the temps outside aren't scorching
zilla68
Moore Oklahoma
oh hell, I thought you already had put gauges on it, yes put gauges on it and see what your pressures are, if it's low, it won't even call for it to kick in.
Philips97
Dane did you get it figured out? I am a hvac tech, might be able to help out a little.
