ad problem...
teambluemxer
medina ohio
started yesterday got the truck all dialed in. WOT pullin hard and bam no FP so i got out shut truck of turned key on and pump was running. no fp. so i opnened the water valve air came out and had FP again went down the road and lost pressure again. did the same thing so i drove and it was fine. well this morning i went out to start truck and now it has no fp again anything i do i cant get it to have pressure. any ideas? already got another pump coming. i have a sump on the truck :wtf:
Lowdown89
Travelers Rest , SC
Trash clogging up something maybe, I know you have a sump but after my fuel system install I was having a problem a lot like yours.... The truck would run great and it of nowhere I would loose pressure ad the truck would run like crap, I replaced all sorts of things before dropping the tank and finding trash that would suck up against the pick up tube after turning the truck off it would float away from the pickup and then once driving it would slowly work its way back over
Redneck6.0L
You you have a regulated return, if so, tighten your filters, loosen the lines to the regulator, turn the pump on till the fuel bleeds out those lines with pressure. Tighten them back up and see what happens. I've seen regulated returns not bleed right and lose prime. Something to try anyways
teambluemxer
medina ohio
is it possible that the pump could be sucking air through a o ring thats bad? causing it not to pump any fuel up? like o the gerotor pump pherhaps?
