Add a circuit
d7es3l
Colorado
Does add a circuit create 2 seperate circuits? Or do they both run on same circuit? Thanks
bad12jr
If your talking about a dual fuse setup. All the power is drawn off the original circuit. All you want to use those for is a power source to close a relay. Not a good ideal to put 20 amps constant through one.
