Adding 4 more inches to a 4 inch lift what do I need?
rem870ex
I'm going to be adding 4 more inches to the front of my truck using pmf hangers I currently have a 4 inch rough country lift and It came with springs, shocks, sway bar and track bar drop brackets. My guess is in order to have 8 inches in the front I'm gonna need a few more things than just hangers such as pitman arm, extended brake lines, extended steering coupler, HD track bar, extended sway bar links. I don't know if I will need bigger drop brackets carrier bearing drop bracket or then lengths of any of those things any help is appreciated thanks in advance -chuck
Sent from my SAMSUNG-SM-G870A using Tapatalk
old man dave
Petaluma, CA
It would help a lot IF you state what year truck you have.
TXGLASSMAN
Keller Texas
track bar, pitman arm drop, sway bar end links, break lines. and I am sure I am missing some things
Icon makes a front box kit for a 7-9" lift that would have all the front parts you need to do this
