Adding Factory Tailgate Camera
VanoFord
Sugarland, Tx
So has this been done? Is it pretty easy or does everything need to be replaced, like the mirror in the cab and what not?
i ask because i'd love a BUC on this land yacht. i know i could hook any BUC to a display tuner, but I havent gotten my tuner/performance stuff done and wont for a bit, but would like the camera.
on my 06 .5T, ford had a lot of stuff just dummy plugged. my 2wd had wiring for ESOF behind the coin holder, and it had wiring for fogs even though I had none, just needed to add the hot to the fuse box. So I was wondering, would I be able to hook it all up w/ minimal wiring, or is it gonna be a PITA and I should just go aftermarket to save some stress. Thanks for all the input?
VanoFord
Sugarland, Tx
Does anyone have a BUC that could chime in?
I assume there is a pigtail on one of the gate hinges for wiring feed to the mirror? Can someone get a pic of this because I hope ford wired up all the trucks and just capped. Thanks!
Big Angry Hillbilly
Going to bet 'no' on the wiring being there and being capped.
I showed a completely different body harness for my truck to have factory subwoofer so I never bothered adding it. Took the carpet up and everything. It isn't there.
Dzchey21
wyoming
From what i understand everything from the handle forward needs to be added
I enquired about it on my new truck and its pretty complicated, there is an outfit that makes kits, ill see if i can find it.
