LovinPSDs
Is it possible to add the manual floor shifter to a truck that has the automatic 4x4 switch? Also would want to just completely remove the auto switch.
If you can find a rolled xl it should have everything you need.
I think all 6 spd came with manual t-case.
I was thinking the 08 and up because the only manual t-case I've ever seen in an 08 is in 6 spd trucks
