addressing front suspension after new rear lift
n54power
So.i pulled all the aftermarket parts in the rear. I ditched the rear lift block,factory springs and anything that is shot. I installed a procomp leaf pack,heavier duty Ubolts and traction bars. Now I'm sitting higher in the rear (springs were from the 6.5" kit)
I recently replaced all the front spring bushings but the springs are pretty worn and don't pair well with the softer rears.
My initial plan was to get the matching front springs and call it good,BUT I'm curious if there's a way to get a nice 6-6.5"lift in the front using factory parts.
Jassman
MS
I dont believe so. Call Cary at CT Performance and let him set you up properly. You could go with just a simple 6" spring from Pure Performance and then get a good shock like Fox. Let him go over the parts you would need to do it right between what you have, what you need. This guy is good, fair on pricing, but has the knowledge of putting the correct parts together is excellent..and his service after the sale is excellent...Im extremely pleased with my set up, and my truck rides so much better than stock, Like a Hot Rod Lincoln on steroids, handles way better, and the build quality of components are extremely stout..everywhere I go people are looking under my truck. Good Luck man...
http://ctperformanceinc.com/
775-835-3569 8am to 5pm
Pacific time. M-Sat
