afe intake
1sicpsd
waterford wi
i have a afe stage2 intake with progaurd7 filter and when i get on it, it sucks the air filter reset closed. any ideas why?
Cknox121
Augusta GA
To restrictive. I have a afe and it will suck the filter minder about a 1/4 of the way in.
No limit is supposedly the way to go
duddy
sloshkosh wi
I have not had an issue with AFE pro5r, although I am not sure on what the difference between the two are. However my no limit intake just showed up.
duddy
sloshkosh wi
I understand the grade of filter change, but the key with flow is the dimensional differences. The air box around the filter may be causing the restriction even.
08BIGRIG
WI
It is your filter that is causing the issue. If you go to the pro graurd 5 filter you will have far less problems depending on what turbos you have. If you are running stock turbos, you will have no problems with the ProGaurd 5. If you have more than stock turbos like even a batmowheel, then I would either switch to the No Limit intake or the AFE Stage Elite upgrade that transforms your current stage 2 intake into a much more free flowing kit. Personally I would just get the No Limit intake and be done. That's what I did. It is easier to take on and off the truck if you are working on it. In a dyno comparison, the No Limit intake made 11hp more than the AFE Stage Elite as well. If you are interested in any of these contact Bigrpowr on here as he is the owner of No Limit and can get you what you are looking for. I belive that his website may be down currently, but he is a great guy to work with and you will be happy that you made a change I bet.
1sicpsd
waterford wi
alright thanks a lot for the help i was just on his website so it is up. only bad thing thing with no limits is u gotta do the ccv reroute right away. but i guess in the end it should be done anyways
