After market brakes
STR8LINE
Barren River Lake, KY
well.. After a Hard stop the other night I feel a slight vibration when on the brake pedal, and just so happens the pads just hit the squeakers as well. So I Know New pads and turned rotors at the Least is in my Near future But, Iam thinking about this deal on autoanything.com
http://www.autoanything.com/brakes/61A5871A0A0A3355380.aspx
Does anybody have a better suggestion maybe?
I did a search on here anseen in a thread that OBSWIZ was the man too contact on a deal for rotors an pads so I p.m.'d him but haven't heard anything back yet.
Any an All advice will be greatly appreciated fella's as this is my first SD, btw its a 2007 CCSB
Thanks In advance
bruce
Middle east
I wouldn't put drilled rotors on a sd. Too prone to cracking. I have applied rotor technology cyro rotors with performance plus pads and ss lines and it shops really well for 22's. Ebc, powerslot, hawk are all good brands.
bruce
Middle east
Fwiw get the cyro rotors. Maybe i just have bad luck but seems like my truck eats calipers. I've had both fronts seize and get hot as *** but the rotors aren't warped. Cary i have sdhq lines and the rf has always seemed to leak. Pm some prices on your stock length lines.
CSIPSD
Bend, OR
245k on my truck...
First brakes done at 100k, and now the fronts are down to the warning tabs...
You guys need to go easy on the right peddle...
Snake
Flo Rida
I must drive like an 80 year old because I got 162k out of my stock rotors. Just installed Powerslot cryo rotors and EBC Greenstuff pad and noticed a huge difference, and the pads are still bedding in.
