stevens6.7
Which gauge would work better mechanical or digital? I only ask because I'm planning on putting a pod pillar and the digital gauges only go to 30psi and I would like a gauge with at least 60psi as I plan to upgrade in the future.
Ah, maybe I saw a different kit then? Think the one I was speaking of was multiple pods with readouts off one cord running to obd2 port. Sorry OP for my bad info.The digital gauges T into the vac/boost line and use their own sensor, not the computer's.
prolly better then factory..So the digital one would be better then correct?
they can yes.. but 60 bucks for a good mechanical or 160 for an ok electric...If you're going off lincolnlockers post, that would be analog/mechanical/needle
You get what you pay for. Electric can be just as reliable as mechanical.
Sent from my SM-T537R4 using Tapatalk
