SickStroke6.0
Okay, so I got my truck all buttoned up. Casserly 190/75's, PowerMax Turbo (for now), and a new AirDog 2 from PTP. The pump is the only thing giving me issues.
The pump is mounted at the lowest point possible on the frame mount, and it is still barely touching the bottom of the cab. It's unbearably loud in the cab too. Maybe stick some Dynomat between the pump and cab?
Also, the pressure never remains constant. The needle is constantly bouncing (verified gauge, it's not a gauge problem) and it will roam around from 65-75 PSI. I adjusted the regulator to run about 68-70 PSI. The pump also doesn't have a constant hum like I would expect, its almost pulsating, and it kinda goes along with the shaking needle. And everyone in a while, the pump will have a louder pulse.
I do not have a sump... YET. I plan on getting one of those low profile sumps I read about somewhere on here... For now I'll just keep it above a 1/4 of a tank.
Here's a video. It wasn't shaking too bad in this video, but you get the point.
AirDog 2 fluctuating - YouTube
