Airdog and fuel bowl fuel filter
powerstroke
San Marcos TX
I recently installed an airdog on my f250 and now its time to change the fuel filters. I am in need of just the fuel filter for the fuel bowl. Is there anyway to buy just that one filter or do I have to buy both of them?
FaSSt9602
Gilbert, AZ
With the AD filtering, the filter in the bowl should virtually NEVER get dirty...I would say you are good.
FaSSt9602
Gilbert, AZ
I replace the AD filters ever 15k. Way more than I need to, but the filters are cheap. I no longer use the stock fuel bowl, but with the AD 2 micron filter, you are filtering down to the same as the stock filter in the bowl anyway.
Dzlnut
Idaho
How do you like the AD2? I been on the fence trying to figure out which way to go. You have any pictures of the install?
java
Texas
When I had the fuel bowl I took the filter out and just used the AD2 filters. Now I have the fuel bowl deleted.
powerstroke
San Marcos TX
I like the airdog2. The only thing i don't like about it is it need bigger injectors! The only reason I upgraded was because of the lifetime warrantee and my stock fuel pump went out. My next upgrade will be injectors and a fuel bowl delete. Ill post pictures tomorrow when its light outside.
powerstroke
San Marcos TX
Im working on it Morgan. Has anyone taken the filter out of the fuel bowl and remove the stand tube in the filter housing and put the cap back on?
java
Texas
That's how I ran mine for about 2 years. IIRC it's just a small torx bolt that holds the stand tube in.
Dzlnut
Idaho
Look forward to seeing it thanks..
