Squat and Poot
everythingw as going great until I was tapping wires. I removed fuse as instructed and tapped the green, green/purple, white, and yellow.
I have the driver side hooked up and working properly (the green and green/purple wire. Now I'm 99% sure I have the right yellow and the right white wire in the sill and panel to tap into. I buy a test light to test leads of the steps. Check the white and the motor arm retracts. Test yellow and nothing happens. Go back to white and nothing happens. Check fuse and it's good. Driver side still functions but passenger has nothing. I don't think it's the motor because it worked that single time.
What should I check? Amp CS isnt open till Monday
If you e had similar issues please post up and share what you did to fix it.
I'm going to crack a beer and try again.
