And the build begins...
purpleheart350
Rokwall, Tx
I have done the intake, exhaust, chip, and gauges. Well today I ordered Stage 1 of my build: a new turbo (Beans D66) and pedistal, and oil cross over line (strictly diesel) (may not be a big deal for some), and as soon as I can get a hold of someone at Terminator I will be getting the T500 (as long as it will work in my 95).
Stage 2: e-fuel convertion, 3 inch SD plumes, smith bro push rods
Stage 3: Stage 2 Rosewood injectors, swamps IDM, arp headstuds, custom tunes
purpleheart350
Rokwall, Tx
You can swap 3 inch plumes in to a OBS and put the 2 to 3 inch boots on it and one of the bolt holes has to be welded over. Other than that they are fine.
purpleheart350
Rokwall, Tx
There was a thread on hear a few days ago about some one did testing on this issue and the SD plumes flowed almost double the air. But the talk on there was about if the heads would allow the air to go through without being ported and polished. I am doing it anyways and hoping that air will be forced in there at a greater volume.
97f350stroker
Burgettstown pa
You have to weld up two of the holes on the sd 3 inch plenums in order for them to work on a 95 motor. The 96 and up motors have two extra mounting holes in the plenums.
