Any A/C gurus out there
kadeninabnitt
Martinsville, IN
Just got the ac all hooked back up on my truck in my sig got it charged up 38oz what it calls for its not getting as cool as i belive it should high side is sitting around 260psi low side around 40 seems kinda high on the high side could this be the orifice tube giving me grief
04cr450
harford county, maryland
Typically a failed metering device would be low suction high head pressure . . Before you decide that, make condenser coil is clean with no obstructions.. clogged condenser coils will cause High head pressure.
Oroville, CA
What's the air temp? And did you pull vacuum before charging?
kadeninabnitt
Martinsville, IN
Condensor is new just installed it pulled it down to 30 on the vac pump the only other thing i can think is blend door issues where heat is hitting the evap core which would cause high pressures from what ive been told
kadeninabnitt
Martinsville, IN
Update new orifice tube it was in ruff shape new accumulator and fixed the broken vac line on the solenoid on top of the blower box and it all see to be in good working order other than a very all leak where the compressor splits
