Any ideas on what would cause
KYkickinit
Henderson ky
Driving home from ts today and about 70 miles from home my truck cut out and every warning light in my dash flashed for just a split second. Happened 4 times but went right back to normal every time. I have no idea what would cause this. Thanks for the help.
ToMang07
Mainah!
Another thing to check is the chip....of course the truck has to be OFF with the keys OUT of the ignition...
Charles
Sounds like what would happen if you keyed it off then back on real quick.
Is the big connector at the column tight? Ever been off for some reason? I would verify that something in the ignition circuit isn't loose or damaged/worn.
Then I would ask if you got water on the GEM. (The under-dash fuse block is the GEM)
The suggestion about a loose chip is also valid.
KYkickinit
Henderson ky
It hasn't ever been off that I know of. I'm gonna check the chip today when I get off today. Can't think of anyway that the GEM would have gotten wet.
Charles
Pretty common for a windshield leak to wet behind the dash and drip down on the GEM. But if you haven't swapped the windshield lately, and don't have any reason to suspect any inordinate amount of rain or water on the truck, then I'd look elsewhere first. Chip may be falling out.
Hell the PCM relay could be dropping out. A number of things could be happening.
Charles
Make sure the relays are all snug in the distribution box. If the PCM relay was bouncing around and dropping out it would be like switching the key off.
KYkickinit
Henderson ky
Found a burnt spot on my air filter. Rigged a piece of cardboard there to keep it from touching seems to have fixed it.
KYkickinit
Henderson ky
There are little black spots where the wire mesh is missing on my filter and a corresponding scorch mark on the underside of the hood.
bad12jr
What wire was touching the filter?
KYkickinit
Henderson ky
No wire was touching the filter. 6637s have like a chicken wire screen around the paper part. The chicken wire touchs my hood.
