Anyone gone from Turbonetics to t4 up pipes?
Six_Sloww
Southeast MI
My stock up pipes are leaking, I currently have a Turbonetics pedestal and vband to t4 adaptor. This mates up to a box s366.
Just wondering if anyone has made the switch from a turbonetics setup to a one piece t4 up pipe and thought it was well worth the money?
Also what are my options for a one piece stock replacement up pipe? I would rather ditch the egr replacement pipe. I know RCD has a high quality piece, anyone else?
Radioflyer
IMO, i'd do the RCD Pipes without the additional egr replacement pipe. Less gaskets to worry about leaking, quality 304 stainless, less of a worry. If ya want a price PM Me. :thumbsup:
Six_Sloww
Southeast MI
So no one has anything bad to say about the Turbonetics setup? I've never been able to compare. I don't want to spend 7-800 on stock replacements if I could spend 150 more to get the far superior setup... If it is superior
Mdub707
Mohawk NY
Yes, just PM'd Zach so he'll stop in here and comment. I know he hated his t4 adapter piece and went to full flow t4 pipes.
I'm running Matt's T4 setup, but I never did the adapter route, went right from stock pipes to these T4 pipes. S362 on stock injectors.
Stroker04
Gettysburg PA
OP I switched from the adapter to t4 up pipes and it is a night and day difference. Spool up is much quicker and seems to have more power up top as well. Well worth the money. You won't regret it.
Radioflyer
I should've been more clear on my last post..too much coffee this morning. I meant to say a t4 set up like rcd.
^ as stated above, you'll see better performance with the charger using that sort of setup and as i said before less gaskets, potential pieces to leak resulting in a better life of the product and less potential exhaust leaks etc. Plus it will make it nicer if you decide to change chargers to a different t4 based unit down the road. The Turbonetic's works for people, and it worked for a good while, but for the extra little bit of coin, i'd go with a t4 up-pipe setup and toss the adapters and what not.
Stroker04
Gettysburg PA
The adapter didn't seem to work well with the twin scroll housings the single housings are a little better from what I hear.
Josh@DirtyDiesels
PA
true T4 divided up pipes will be night and day difference. I run and sell MPD's up-pipes. Shoot me a PM if you want a price.
