Anyone running a Stage 3 or 4 Colt Cam?
04cr450
harford county, maryland
I rode In a 6.0 similar to yours extpower. .. he had a colt stage 3- this was two summers ago and I did ask him what kind of modifications he had to make... he said he didn't know as the motor was built and the engine builder recommended the s3 along with the parts needed to make it work (pistons, valve springs, push rods ).. I am certainly not familiar with these s3 and s4's but that truck had zero lag(has hybrid injectors, mass diesel tuning, and Compounds non vgt's) and did have a chop big cam idle. I know, no help but at least I rode in a truck that had what u asked about lol
Extended Power
Yeah, I'm just gettin to used to the power again:fustrate:
It's so addicting...
I'm pretty much done with turbos now...well, once I get the new housing for the 69mmSXE...then it's move up on injectors...and cam...that's it.;)
04cr450
Just go all out and get a stage 4 come on lol... u gotta everything else!.. was doing a little reading and by the design. Of the stage 4 it looks like it is a high Rev cam?
Extended Power
Sounds like the stage 3 & 4 are able to rev to 5000rpm.
Stage 4 just has a little more lift.
FaSSt9602
Gilbert, AZ
Do you have enough PTV room for a stage 3 or 4? I know nothing about the specs of either, but I'm assuming it has more lift. IIRC you had reliefs in your pistons already, but will it be enough?
Extended Power
Yeah, if I remember the reliefs are like 0.080" ...maybe more.
Here are the specs:
It's only another 0.050" lift from what I run now, so the reliefs should be good.
HOOV3R
Central PA
From Facebook
NEW PRODUCT ANNOUNCEMENT!
Its been a wait.. But here they are! Affordable new billet cams for the 6.0L and 6.4L Ford Power Stroke. All made in the USA.
Four stages.
Stage I $649
From hot street trucks to dump trucks.
Drop in replacement with corrected valve timing, increased lift and duration for efficiency VS the OEM grind that was designed to promote EGR Flow.
Works with stock valve springs and RCD upgrade 120# springs.
No Piston fly-cutting required.
RCD Chromoly Push Rods recommended.
Duration
170 IN / 185 EX
Valve Lift
.385" IN / .368" EX
Stage 2 $699
Hotter Street use.
Drop in use, no piston fly-cuts required.
RCD 120# Valve springs recommended for competition use.
Optimized valve timing, increased lift and duration for maximum torque, horsepower and mileage.
Duration
181 IN / 195 EX
Valve Lift
.412" IN / .400" EX
Stage 3 $749
Hot Street / Competition use.
.060" Piston fly-cuts required.
RCD 120# Valve springs required.
RCD Chromoly Push Rods Required.
Optimized valve timing, substantially increased lift and duration for maximum torque, horsepower.
Duration
187 IN / 208 EX
Valve Lift
.467" IN / .450" EX
Stage 4 $799
Extreme Competition use only.
RCD 120# Valve springs required to prevent coil-bind / valve float.
1.850" installed height.
Blueprinting of cylinder head required to ensure valve installed heights and to prevent coil-bind.
Optimized valve timing, substantially increased lift and duration for maximum torque, horsepower in competition vehicles.
Duration
197 IN / 218 EX
Valve Lift
.518" IN / .500" EX
Extended Power
0.100" more lift than the Colt Cam stage 4!!
That's a lot more!
Wonder what the power range would be...2750-5000?
Extended Power
I'm very interested in those!
That's gotta be the most lift on a 6.0L camshaft Eva!
Stick some Harland Sharp roller rockers with higher ratios, and just Go to Town!
FaSSt9602
Gilbert, AZ
Hmmm, something seems odd there. Wonder if they are showing the lift with the same 1.4/1.42 that the Colt card says. I can't imagine they would be THAT much difference. That is a TON of extra lift.
