West Point
The Library
6.0 Tech & FAQ
Asheville long block
[QUOTE="AshevilleEngine.com, post: 1568970, member: 11592"] Even if you bought all new pumps, turbo, injectors, and the Bulletproof stuff, you shouldn't have to be spending $20,000 for somebody to install your long block. To figure out how you are being gouged, just add up the cost of all the parts that you are replacing, then add the cost of labor (amount per hour times 35 hours). The only thing other than the add-on parts that the shop will have to provide is coolant. Add that in, too. The figure shouldn't be anywhere near $20,000. You might have to find a different installer. Let me know if you need a list of shops to call. [/QUOTE]
02 F250 7.3 Will crank, WTS stays on, no start, no OBD
Latest: Sterling6.7
Jun 7, 2026
7.3 Tech
P0087
Latest: DEEZUZ
Jun 7, 2026
6.4 Tech & FAQ
2015-2019 6.7 HPFP New In Box
Latest: lincolnlocker
Jun 1, 2026
Engine and Drivetrain
First 6.0L (56k warning)
Latest: adrianspeeder
May 26, 2026
Extra external motor oil cooler?
Latest: justinlogue5_0
May 26, 2026
7.3 Tech
West Point
The Library
6.0 Tech & FAQ
