Rmartin-97
Is 45 pounds of boost and 60 psi of back pressure bad? Should I look into a wastegate?
is that before or after you subtract the barometric pressure?
What's the barometric pressure?
I think he means atmospheric pressure. It depends on your elevation. I think sea level is 14.7psi. I'm not sure how the H&S reads it. On the DD you have to subtract it from the reading.
What's your elevation? The pressure goes down as elevation goes up. Turn the key on and see what the reading is with the engine off and that should be atmospheric pressure. You need to subtract that from the absolute bp reading you get while it's running.What would I need to do to figure it out.
Correct. So when you're driving and its showing 24psi. It's actually only 10psi.
If i'm thinking correctly right now, if the back pressure shows 0 with the key on while baro is 14, then its already subtracting 14 for you which means what it shows is what you have. If back pressure showed 14 at idle or engine off, then you would have to subtract 14 to get the BP number.
I believe he can monitor both. Absolute and desired. Just be aware of which one your are watching when getting rough with it.
Now I'm confused again.
I'm pretty sure ebp is what you want to be watching and if it shows 0 key on engine off then it's already subtracting atmospheric pressure.
Sent from my DROID RAZR using Tapatalk
