Back to stock... Tuned with egr??
Monotalonawd
Quebec, Canada
Hi! Putting my truck back to stock for trade in! But had a question... Im tuned with a spar tan, i had an egr ****** kit and now i just put back the stock cooler in place. Still no dee pf. Can i use the truck with the tune? I assume the tune turn off the egr but just want to make sure. Eventually i Will put everything back but need my truck on the road asap lol :p thanks
Monotalonawd
Quebec, Canada
Thanks!! Some of you who put it back stock had problems with the def pump clogging? Mine has been tuned since spring... It is still on the truck.
jwalk09
VA
Yeh should the def tank be cleaned out if there is a chance returning it to stock or will it be alright to leave the fluid ?
Monotalonawd
Quebec, Canada
Si i put the dee pf back. Everything was fine for about 30 min. Then i turned off the engine. When i got back in the truck i got the reductant injection valve stuck code... I suppose it has to do with the def system? I just cleared the code and left my 2016 to the dealer.
Now driving a 2017 f350 platinum :toast:
