Bad vibration in 4hi
dentexpowerstroke
denton, tx
Truck started having a bad vibration in 4hi when racing. Feels almost like wheel hop yet there isn't any. Only does it in 4x4 when I'm on it hard in high tunes, doesn't do it if I just cruise in 4hi also won't do it in 2wd at all. Anyone had this issue? I got under it this weekend and tried to see if anything was loose or rattling, came up with nothing. I'm figuring it's probably u joints that need replace but wanted some opinions.
TrailerHauler
Michigan
Would you be able to narrow it down by, driving with just the hubs locked in 2wd, or hubs unlocked in 4x4, or does it need to have a load before it will vibrate? That could help point to axle shaft joins, or a drive shaft joint. The slip joint on my front drive shaft need to be replaced because its all blow out, gives me a nice vibration at high speed in 4x4.
dentexpowerstroke
denton, tx
Hubs stay locked all the time. It only does it in 4x4 on wot runs. It usually happens close to 40ish mph. I've tried to make it happen any other time and it doesn't, I tried all other variables.
Fordkid
why are your hubs locked all the time? you damage many parts doing that.
Explain. Been doing for many years with no issues. 200,000k plus on one of the trucks. Unless your in 4x it just free spins
Jarrod B
Corpus Christi Texas
Ahhhh that might be the difference then. I was always told from others not to have locked hubs or locked transfercase on dry road due to the binding it does on the drivetrain up front. Ford even said not to be in 4wd on dry roads.
Now having the hubs locked and transfercase in 2wd idunno. In my case, my hubs are frozen on auto so they are not able to be turned. But still hold the vacuum and works with the switch.
