JerseyJim
Hey guys, thought some of you might find my UOA results comparing the Baldwin B7039 vs the Motorcraft FL-1995 interesting.
The most obvious difference was a reduction in insolubles (solid particles) from 0.3% with the Motorcraft to 0.2% running the Baldwin. According to Blackstone Labs, the value should be less than 0.6%. That means the Motorcraft does a fine job but the Baldwin does better.
Said another way, that 0.1% reduction in stuff floating around the motor in the oil means the Baldwin does a 33% better job of filtering solid particles than the Motorcraft does.
BTW, the time on oil is comparable: Between 3100-4500 on the Motorcraft and 4200 on the Baldwin.
Best,
Jim
Best,
Jim
