Banks IC and IC tubes with coolant filter
TXGLASSMAN
Keller Texas
Guys I am wondering if you install a banks inter cooler with the bigger inter cooler tubes will a coolant filter work as well cause I know the coolant filter mounts in the passenger side above the IC tube
Will be running a sinister coolant filter kit
Anyone have any pics of this set up already?
hawgdoctor
king george, va.
I know the filters work with any of the aftermarket I C's. Have put them on with the banks, and with the speerco's with no interference problems fwiw.
TXGLASSMAN
Keller Texas
Good that's really what I needed to know I was afraid the filter would hang to low and not go in with the bigger banks IC tubes
redracer62
Arizona
I had to mod the coolant filter a little bit so it wouldn't hit the banks ic pipe. It's pretty easy to do.
MorganY
college station, tx
It worked fine with my banks IC pipes but I recently had it relocated to the pass side frame when I added a BOV, much better location.
