Battery light on!
LiftedBlackHD
Battery light came on last time i drove the truck. I had some time today to mess with it. I cleaned up the terminals and still the light is on.
I hooked up my SCT and it's reading 11.7 volts while running with nothing turned on.
I unplugged one battery and it dropped to 11.4.
I unplugged the other battery and it read 11.4.
I unplugged both batteries and it immediately died.
Btw I am running a 6G 140 amp large case alternator from Quick start that I bought in 09.
The batteries are wal mart specials from 2008. :(
Any help would be appreciated.
Btw I still have the factory batteries in the garage that i wanted to have refurbished.
HeavyAssault
Middle, VA
I try to do the same thing. Strange thing is my batteries have a 36 mo warranty and tend to fail at 30-35 months. VERY strange.
Lassie
Tenn River Alabama
You can have all of these tested for free at most parts stores. Just have to be willing to leave batts overnight for a load test.
No way to tell if alternator is good if hooked to dead battery/batteries. And with their age, they are almost certainly shot.
LiftedBlackHD
Im just gonna bite the bullet and buy some new batteries this weekend. From now on I think they are going to mysteriously fail every 35 months!
I still have the original set of Motorcraft batteries in the garage. Any ideas of what I can do with those?
Mine was doing the same thing yesterday. Swapped out the alt. And im good to go.
You Should be charging at atleast 13v when running
Sent from my SCH-I545 using Tapatalk 2
LiftedBlackHD
Well I bought two new batteries and i'm still only getting 11.9 volts according to my SCT. Battery light is still on.
I'm assuming it's the alternator. Pretty disappointing because it's a 6g 140 amp from alternator parts from 2009. And apparently they won't give me any credit if I return it to them and by a new one.
loboost
My truck reads around the same but no battery light....I'm certain my batteries are toast...I can fully charge them..and load a tune and they're dead again. I'm going to try a desulfator once before replacing them. If a battery has ever been dead cold for any amount of time ...its hard to bring them back to life.
Lassie
Tenn River Alabama
It's very common to lose alternators when a battery drops cells. Just hope it hasn't killed your FICM already too. Now, change batteries every three years and you wont have to buy more alts. :thumbsup:
Redman920-06 350
Wisconsin
Batteries and Alternators are a common unnoticed/maintained items. No one checks until that little light comes on. Shame really. I had a F150 OBS that had been in the family since NEW, Still had the Factory Installed ALT. LMAO.
LiftedBlackHD
Put a new altenator in... Problem solved!
I still have the bad Quick start 140 amp large case alt. is it worth it to try and rebuild it?
