BD 62mm with 175 75%
Twan
Berthoud, Co
Anyone running this set up? What are your thoughts, anyone running it at high elevation? Looking for a good tow set up, heard good things about it.
doubledee715
is the bd thruster w/diverter a divided housing? and how does that work with y pipe exactly? Is it a t3 flange inlent that needs a vband adapter just like the open housing?
Twan
Berthoud, Co
Right now I have a powermax stock injectors, talking with pizza pig and I'm thinking that is the turbo I want to go with, just hoping it will spool better than my powermax on tow tune.
What kind of egts and boost do you see on a wot run?
Thanks.
kevin
springdale wa
its a divided housing. the diverter is the adapter, its a drop in kit, it is not easy to install by no means tho, no fab work tho
kevin
springdale wa
Thanks.
mines waste gated at 37 psi.. on X-race on a 1/4 mile run i see about 1450 with the probe in the exhaust manifold, at 60 mph on flat ground it stays about 600
kevin
springdale wa
i have extended cab long box with 4 inch lift on 285s and ran a 13.4... as far as a dyno, the one i was on said 520hp but i would say thats a little high
windrunner408
According to a HP calculator using your ET, it puts you at 520. Eitherway I would say you are definitely over 500Hp.
Hmm. This sounds like my perfect setup that I am looking for. What size nozzles do you have in your injectors?
windrunner408
I am sure this has been asked but what are the specs on this turbo??
How is thought that this turbo would compare to a waste gated 62/65/.70 with a t3 open housing and no diverter valve with 175/75s with respect to towing and normal drivability??
It seems that it would cost less with such a turbo as opposed to the $2800 that this thing costs. Nevertheless, if driveability were to suffer too much then it would probably not be worth any savings.
kevin
springdale wa
i didnt measure it, but a guy at BD said its a 62/70... the website said 61.5 but maybe that how they measure
Worstenemy453
Fredericksburg, Va
Also you have to remember than you'll need a pedastol for a non vgt turbo. RCD's is like 650ish i think retail, i can do a little better on them though.
As far as driveability, i would venture a guess at the BD being better because of the diverter and bigger turbine side. Means itll spool good down low and still have a good run out up top. This is just going from logic as i haven't installed one here yet.
FX4 F2-Fifty
East Houston/San Marcos
The diverter valve doubles as a pedestal I do believe.
Sent from my DROID BIONIC using Tapatalk
patrickke
Lexington,ky
It comes in a kit with everything...
You can get a nonvgt. Setup cheaper.... especially if you get something off of the shelf and get a turbonetics mount kit
strokin6L
Springville NY
some non vgt turbo's come as a kit with the pedistal and everything to install it without having to buy the turbo and pedistal seperate.
Pizza pig
MD
like the BD and RCD kits, rcd is a dealer for bullseye now, or iwll be very shortly so i would think they have kits ready soon?
wait for Jared to chime in
