Beans 6-position
RedPowerstroke
6 position Beans chip with stock, tow, daily driver, performance, drag race and smoke/lope tunes. Tuned for a stock truck (stock transmission, turbo and injectors). Also included is the laser engraved switch plate that goes behind the knob, and a custom mount plate that goes where the electric 4wd switch is in some trucks. Asking $400 shipped.
Lang
You can sell the chip, but tunes for your truck will not work on someone else's
RedPowerstroke
As long as you have an NVK4 PCM, it will work fine, that's what my PCM is. It will also work with other PCMs, but as far as which ones goes I don't know. I'm open to offers, but keep in mind this was over $500 new.
Lang
It's not $500+ anymore...
RedPowerstroke
I just went to their website, put in all the tunes mine has, and came up with $504 before adding the bdp switch plate and shipping.
$504 plus the $15 or $20 switch plate plus shipping is, believe it or not, over $500. If you aren't interested in my chip that's fine I understand, but don't continue posting misleading and uninformed information on this thread.
RedPowerstroke
Why are you selling it?
I am selling it because I am planning on going with one of PHP's new Hydra chips which is USB updatable. I am in the process of building my truck so things are changing and I don't want to have to pull this chip and send it off for reburns every time I make a change.
Lang
If you'd like ill post my bill up for $474. That was 2 months ago
PSDEng
Bellefonte, PA
OP, the point he is trying to get across is that YOUR custom tunes don't mean squat for somebody else's truck. They're buying your chip, and there's a 99.99999% chance that whoever buys it will have to send it in for a reburn and pay for it....just sayin.
Lang
Exactly. Op I was trying to inform you, but your ignorance has overridden so ill inform potential buyers. FYI you can buy a burner for $250 new or used one for less and Jonathan can email tunes. No need to send the chip in
STROKIN N STYLE
GOM via NC
Its for a STOCK injector truck. Nothing custom about them. They'll work as long as the PCM code is the same
sent from the sea
RedPowerstroke
I believe your ignorance is the problem here. I don't know what makes you think you know more about MY chip on MY truck than I do. THESE ARE STANDARD BEANS TUNES FOR STOCK TRUCKS, NOTHING WAS CUSTOM TUNED FOR MY TRUCK. If you have a truck with stock injectors and turbo and called Beans and ordered a chip right now, these are the tunes you would get. BTW, good luck buying a burner, buying a chip, and then PAYING FOR EACH EMAILED TUNE FROM BEANS LIKE YOU WOULD HAVE TO. I'd hate to know what that would cost...
RedPowerstroke
Just to update anyone who may be interested... I did some research today. This chip will work as is on any NVK series PCM, and supposedly the PMT series also. This means if you have a PMT or NVK you should be able to plug it in and go. There may be others it will work with, but I would have to call a tuner to make sure.
bluedge8
Champlin MN
sounds right, when I bought my chip Matt said he burns the chip to be "reprogrammed" to the NVK series no matter what you actually have.
