Bending 4" Pipe
JWaltz
Does anyone know a place that will bend 4" pipe? roughly in the Indianapolis area?
WILD_PHIL
East TX
Hope you have better luck then I did. If you find a place great, but dont get ripped off. It may be cheaper to just buy the pieces yiu need. I built my own y pipe kit using 6 inch exhaust pipe for 260 bucks. 10' stick and 3 6" elbows.
Sent from my SPH-L900 using Tapatalk 2
ford rules
Ya good luck, better off buying sections. You can get 30* 45* and 90's usually.
JWaltz
Ya i think thats what im going to end up doing, tried peterbilt they said use flexpipe not a big fan of flex pipe gonna be hard to peice angles together need a tight 180
kadeninabnitt
Martinsville, IN
I know there was a place in Muncie that a friend of mine used to go to other than that I don't know of any one you can buy prebent sections at truckpro at Thompson and Harding in indy
Adamv7010
What's the od of 4" exhaust pipe?
I'm an electrician...we regularly bend 4" EMT which is very very close to exhaust pipe if not the same id & od
