Best 6.0 clutch zf6
jrex2506
Seeing everyones opinion for a clutch. Im about 475 right now, and tow once in while up to 12000 pounds. is there a good single that would work, or just step up to a dual disk?
SlowSmoke
Sylvan Lake, AB
I like using the Dual Disc Soutbend clutches. A little noisier than single disc but much smoother engagement and softer pedal.
B585Ford
WV
I assume you were referring to the 3250. Do the 6.0s have different hydraulics than the 6.4s?
cam91
Fort Mcmurray, Alberta
My southbend single is pretty good, haven't had any issues towing, but I only use the clutch when starting the rest of the time is no clutch
Sent from my magic poop stealing water chair
