TheSmokinStroke2002
What would you guys say is the best way to connect a wiring harness together? I was thinking solder and heat shrink but i am looking for any other options to see if there is anything better.
Konnor
Konnor
how hard is it to set those up?
I use small splices and a good shrink wrap most of the time. Solder is nice but does add some resistance to the circuit. Sometimes not enough to matter though.
I have never seen s solder splice add resistance to a circuit as long as it is done properly. You actually can not get a better splice.
Exactly! There is nothing better than solder, you just have to do it right, a good solder job should have no solder coming out of the wire. I soldered every connection on my truck, checked resistance and never had over 1-2 ohms of resistance from a soldered connection. I wouldnt do it any other way.
Matt what would you recommend for a good solder gun?
Sent from my DROID RAZR using Tapatalk 2
I got an old craftsman one from my dad and its worked great for me.
The thing about soldering guns is that you don't need to go expensive to get a good one. You can either get the gun type or the iron type. The iron type will stay hot all the time and you need to watch where you put it down where the gun type will cool off but not very fast. I have both and when doing quite a few splices I prefer the iron, if I am doing one or two then the gun gets the duty. Either one can be had for less than $20.00 and usually for a lot less than $20.00.
If you do use a soldering iron you need to use rosin core solder for electronics and not acid core that they use for plumbing.
Anybody got a link to the tool for the Duetch connectors. I always solder, but when you need to add a plug the duetch look like factory.
Would they accept factory pins pulled from parts vehicles?
On the soldering irons def. be careful where you lay them. I have a real nice scar on my left forearm from not paying attention to where I laid mine. Branded in. :doh:
