BEST way to run a fuellab
what a mess
rockford il
what the best way to runa fuel system wiht a fuellab is it wiht a low pressure fass or air dog feeding it or is it with it by itself with a pre and post pump filter thank for the addvise!
Pizza pig
MD
Run it by itself with a pre and post pump filter, theres no need for a low pressure system, it will do just fine on its own. Which pump are you looking at? I recommend a sump for the pump to draw from, these pumps need minimum -10 (5/8) fuel line supplying the pump, I dont recommend using the larger pickup tubes, i've never experienced one that didnt suck air on low fuel tank levels.
4.0l sahara
shelton,ct
My 5/8's pick up tube works fine and I've never sucked air. But if I was doing it over I would buy a sump.
what a mess
rockford il
ok thank u guys i will need to order some 5.8s then i got 1.2 coming jsut 5/8s to the pump right and yes im usen a sump and im not sure waht pump it is i bought it from a guy here he siad it fueled his 285s jsut fine tho
Purdue_stroker
Ladoga, IN
Pre and post pump filters and a sump for sure. Theses pumps aren't made to lift. They need to pull from a gravity fed sump. Call up jake@irate diesel. He's a sponsor on here and he will hook you up with a setup all put together ready to go
Purdue_stroker
Ladoga, IN
faster6.0
Go to a local tractor store a goldenrod base and filter will run you 25 bucks + or - and as 1" npt in and out
Purdue_stroker
Ladoga, IN
I have all 1/2" before the pump. The irate kit was set up that way. And I got my sump from beans and I called and got em to put a 1/2" fitting on it opposed to the 5/8" they produce them with
strokin6L
Springville NY
i have my fuelab being fed by a low pressure FASS pump. Dennis at Strictly Diesel actually recommended the fuelab pump be used with a low pressure pusher pump. I've been running it like this for over 3 years....awesome setup. I have 5/8" line from my Hellmann's sump into my low pressure FASS. Then 5/8 line from FASS and into fuelab pump. Then 1/2" line out of fuelab and into Y-block. Then two 3/8" lines out of Y-block going straight to front of heads.
Mdub707
Mohawk NY
The pump sits higher than the sump, so not quite gravity fed still...
Purdue_stroker
Ladoga, IN
I agree. I tried to mount the pump as low as I could. But it's not near as much lift as it would be through a straw
19stroker97
Morehead, Ky
It is gravity fed, the weight of all the fuel pushing down creates a syphon which helps push the fuel from the sump up to the pump. The more fuel in the tank, the less the pump has to pull. Its hardly pulling anything compared to a straw..
