Big Thanks to Nate @ WPE!
rman
SoCal
Just wanted to give a quick little praise to Nate and WPE.
Picked up White Rain (and White Tow) back in November and it ran great, but had a weord flutter at 50% or more throttle. Nate revised it a few times and got it to run great, albeit a bit less power. I was bummed because of all the tunes I've tried, White Rain was my favorite by leaps and bounds.
To keep it short, it turns out I had a failing pump. Replaced the pump with a Delphi and loaded up the original White Rain, and she RIPS! Emailed Nate (mind you, this is 5 months later) and he was so relieved that the truck was running as it should. Sent me another revision to squeeze a bit more boost out, and MY GOD I am in love.
I also run Looney, Looney Wild, a custom-tweaked Looney Wild PCT, and TSD's SPD.
I do enjoy all those tunes, no complaints at all - - but White Rain is just enormously different.
Crisp shifting, right where you want it, more power down-low than you can imagine, and holds the power throughout the powerband. A great mix of useable in-town power and driveability, and linear power from there.
Thanks again Nate!
Sent from my Nokia 5160 using Snake
Kbuterbaugh04
X2 on white rain. I'm going park to stock and that will be my tune.
Shifts do have a significant amount of firmness as compared to other tuners, but are super quick.
White street is a good tune for wet roads as the boost doesn't come as strong.
Glad to hear he's keeping up the great service!
Sent while hiding in a corner.
rman
SoCal
My last truck was a HD F150, 21psi w/ the 4R100 and an original/older Factory Tech Valve Body... that was firm all the time and neck-snapping at WOT lol. I actually prefer firm shifts
