nasty6.6
Has anyone run wmo on bigger injectors like 250/100s without a bunch of smoke at idle??? Does it hurt to go to a single shot injector vs the split shots when running 50-70% wmo?
I would burn up to 100 % WMO. With standard tunes I could only see visible smoke on a cold engine. Ran for over 5 years of all percentages tried to stick to waste ATF but would use WMO also. Slightly down on power when towing otherwise couldn't tell the difference. I had sawmps tunes at the time.
My truck WAS stock when I ran it. I cant say without looking at my records but I came home in the summer of 2010 and filled the tank up with filtered, heated atf/wmo. Like I said, haze at idle. Because egt's drop below 500°. At 300° it would haze as you arent burning the oil completely.^^^ I want to understand what's different from your situation to mine. I have smoke on a stock truck. Not at first, but after a while I do and it's obnoxious
Around how many gallons did you burn?
What percentage?
Mostly highway or city or back roads?
Do you typically drive above 1800rpm ?
Auto or manual?
Mods to engine?
The WMO you used, was it your WMO or did you get it from a shop. Was it WMO or WTO or WHO or what?
We need to figure out what the people with success are doing different than the smokers
Good info tycorr.
Mine ddnt smoke at all driving down the road and very well could have been EGT related. I never noticed more power though. Just wanted to use up a bunch of old oil.
In a higher mileaged 7.3 with injectors it ran good. Nice power.
Im fairly damn sure the smoke is always egt dependent when you are burning oils. I also think.atf burns nicer but you'd be splitting hairs there.
If i ran out of fuel and at home Id filter up a batch and run it. I just was told its not.a.good idea in trucks because it can coke in the injectors. I stopped instead of finding out the hard way.
