Biggest injector stock oil can push?
Motostroker
I'm on tapatalk and the search function sucks. I'm sure this has been debated. Can 225/100s be supported?
Pizza pig
MD
I run 225/100 with stock oil. they will need to be detuned. Also depends who builds them.
Extended Power
I ran Casserly 225/100's with '05 wavy oil rails, and a Adrenaline HPOP from Bob at Dieselsite.
I could drop the hpop down to 2200-2300 psi with a race tune at wot.
windrunner408
While certain injector builders have different ways of building so called "225s", I highly doubt that there is a single HPOP (in and of itself, unless you do some sort of HPODS) out there right now that can hold a solid 4+ volts of ICP with a tune that runs enough PW to fully stroke the injector regardless of who built them. Hybrids don't count unless you want to sacrifice injection pressure.
I would say 205-210cc conventionals (again depending on the injector builder) are about all that a single HPOP can handle and depending on whose truck they're going on would depend on whether that number is too big.
FWIW, Adrian's truck ran about the same as Ivan's with the Adrenaline pump and Warren's 225/75s.
powerstrokedkid87
New Jersey
from what I hear and have seen, 225/100 is the safe limit, originally I ran 205/100s with no problems, im currently running 265/125 and I loose icp. id say a 205 or 225 should be fine
