Billet fuel cap
cfdeng7
CT
Thread your sensor in. All the caps I've seen are 1/8 npt which is what 99% of pressure sensors are.
cfdeng7
CT
Just make sure the sensor is the same thread pitch as your cap. They both should be 1/8 npt.
Jeremyleggett07
Katy, Tx.
Is it better to have a liquid filled gauge? I know the reading is a little off with them as the temps change under the hood
cfdeng7
CT
i prefer electronic gauges especially with fuel and oil. do you really want a fuel line running into your cab to a gauge?
Agjake11
Rosenberg TX
I went with a glowshift for mine since it was simple and cheap and just wanted to know what my pressure is. Gauge runs about 65 iirc
AKHILF
Eagle River Alaska
Your not going to want an under the hood one. You need to be able to see what your at, at wop. Get one for in the cab. I thought I read a while back edge was making an attachment for the insight and cts?
