Blinking OD light
89 Stroker
Southern Cali
had the harness from the PCM to IDM to engine replaced and now the OD light is blinking while driving and my 4 HI light is staying on / Blinking'
tranny shifts fine and worked perfect before a shop replaced the harness
this is on my 89 F350 with a 97 E350 engine in it
89 Stroker
Southern Cali
disconnecting the batteries did nothing, trying to find my code reader around here but have had no luck , i dont have a tach in the truck although the speedo does work properly
Parker, TX
Where did the shop get the harness? There are differences in the early and later harnesses, especially at the firewall feedthrough (C202). Cheers!
89 Stroker
Southern Cali
We had bought the entire engine harness from a place that pulled it from a 97 shuttle van that was running, the engine in this truck is out of a 97 E350 ,
