eiorg9
- Joined
- Feb 7, 2015
- Messages
- 38
- Reaction score
- 0
Ok so i had some leaks in my cooling system and wanted to get them fixed since i know had the time to do so. I had fixed one of the RAD houses and wanted to check for more leaks. I was told to stick my air compressor hose on the degas bottle and that would tell me if i had any more leaks. Well i did so and didn't see any leaks. About 20 minutes later i was changing my oil and suddenly the freeze plug that is directly above where the tranny connects came dropping down and hit the pavement. I was very shocked. Since i had just pressurized the system (obviously more than i was supposed to) so i just blamed it on that. It was very difficult to get the plug back in so i used an expandable freeze plug instead. Well i had planned on doing a lot of upgrades/maintenance on my truck since i felt it needed it and we had just moved from TN to AL so i took the time to get my truck in tip top shape. I installed a MISHIMOTO radiator, then did an EGR delete kit, installed a cooling system filter, and since i had rust in the cooling system
i decided to do a cooling system flush as well. When i got done and turned the truck on i saw a lit wrench where my mileage and odometer are. I drove it around a little while simply to finish the flush changing from tap water to distilled. i had removed the thermostats and replaced them with new ones after i had put in the distilled water. Right when i was about to mix the distilled water with the recommended gold motocraft coolant my truck got so hot i had to pull over. i was less than a mile from home so i let it cool and then got my truck home. So today i went under to see whats the problem. Well i realized that i had gotten an expandable plug one size too small and my truck spit it out. I got the right one back in there and then went to fill the degas bottle. To my surprise i saw water poring out the bottom and then learned that 2 more of the freeze plugs had been pushed out. So now I'm lost. I don't know if i got them super loose when i stupidly put the air compressor to the degas bottle or if i have a more serious issue going on. So i need the help of the experts on here to help me as i am really freaking out. The last thing i want to do is to take it to Ford. So please if anyone has any info please let me know. I won't do anything until i get marching orders....
Thanks you very much.
