Bolt Size
TheFonz6.4
S.E. Idaho
Hello all I was installing a new downpipe and pyrometer in my up pipe today and noticed that the two bolts that hold the two turbine housings together were missing? I looked on top of the motor and did not see them. Would anyone happen to know what size bolts I need to buy to replace them? Thanks for any help on this.
78f100
Bonifay FL
They are not supposed to be bolted together. The holes are there for mating the two together then get removed. Your good.
If your talking about the 2 bolts between the turbos where the seal is
