Mwilbur516
- Joined
- May 22, 2011
- Messages
- 4,700
- Reaction score
- 2
I just wanted someone to explain to me why most tunes run 20-25psi @ WOT? On my Looney Wild I can see 32-35psi if I slowly roll into the throttle while the converter is locked in 6th gear, but when it downshifts and revs up, the boost drops to around 22psi. If you hammer the throttle it'll run to about 25psi then drop back to around 22psi as it runs out.
I've been told that high boost doesn't necessarily mean more power. I would just think that more boost would eliminate any smoke/haze during WOT throttle runs. If someone who knows more about this would explain, I'd appreciate it.
