Brakes acting up in cold weather
Winchester, VA/ Bloomery, WV
So truck has been parked for a few days and the temperature today is the coldest its been all winter, about 0* with the wind. Got in after letting it warm up and noticed the pedal was extremely hard, would only move a little. Took it down the road to see if it would work itself out. They stayed stiff at first then as I would hit the brake, the pedal would move down on its own, and the brakes would sufficiently stop the truck. However, the pedal would not come back up on its own, I had to pull it back with my foot. I've noticed a lot of issues with OBS brakes are vacuum pump related, but didn't find anything exactly like what is happening with mine. I just find it strange they started acting up with the cold weather
Parker, TX
When my brake pedal was "sucking down" on the application of the pedal (and also not "returning" as quickly as it normally would), it turned out to be my brake booster (Note: My problem was not related to temperature). I got a new one from Ford (I ordered the "zero-loss" booster for no particular reason) and problem solved.
Brake Booster, Zero-Loss (94-97)
(Ford) F5TZ-2005-CA (not a service replacement; it must be ordered by the part number, not vehicle application … from TSB 96-25-19, but TSB number not verified)
Cheers!
backwoodsboy
Merica
My guess would be you have condensation in the vacuum lines. I experienced similar issues with an old plow truck.
I used PolyWater Electric Contact Cleaner to purge the vacuum lines an never had another issue after that.
How did you go about doing this? Just pull a vacuum line it's running and add the cleaner? I'm definitely thinking it's frozen somewhere, as I had the same issue yesterday again.
96farmstroke
Did you ever resolve this problem? I am having the same issue now and can't find a solution(I recently replaced pump and booster).
