Brakes are terrible
lariat 7.3
Ever since i have owned the truck the brakes have been real spongey/hardly working. I replaced the master about 2 years ago maybe more. Didnt make a difference. I've bleed prob about a gallon of fluid through them and no change. Power steering pump is fine. Its been flushed. Pedal doesnt really do anything till it gets to that "rubber ball" feeling. If i keep my foot on the brake and shut the truck of it goes straight to the floor. Do i need another master?
JLDickmon
take the calipers off, and look at the wear on the pads..
not "how much is there," but more like are the worn evenly heel-to-toe?
I'm thinking you have a caliper stuck on one slider and it's flexing when you apply the brakes..
when you
, this is the hydroboost unit dumping all it's pressure back to the PS reservoir
lariat 7.3
I feel like the master is just allowing all the pressure to bleed by it. Compared to the other 7.3's i've driven they have actual pressure on the pedal you can feel. Mine is just mushy and non existent. I've even service bled the ABS unit with my AE. Yes im sure the rubber lines are shot. 245k on them
crowz
Administrator
Administrator
I think the key to what you said in your first post is "When I cut the truck off the pedal goes straight to the floor."
THATS a bad master cylinder.
ToMang07
Mainah!
I agree, sounds like the master cylinder.
Did you bench bleed it when you installed it the first time?
lariat 7.3
yup bench bled it per the instructions, is there any difference between lets say an OEM ford one or The better quality parts place masters?
Southmike
you said you bled the brakes have you done a ps flush?
Charles found a master with more metal in it iirc. He had some sort of issue that fixed it
not sure who made it if it was napa etc. Maybe someone remembers
wyomingtrucker
Columbus Tx
I'm having the same issue with mine. Replaced everything on the rear end, new master cyl, new lines to the back, new push rod for the master cyl and flushed everything. Guess I'll change everything on the front now and see what happens. I'll let you know when I get it changed if the front calipers needed done.
Sent from my iPhone using Tapatalk 2
lariat 7.3
no external leaks, put a brand new master in today. improved some not much though, pretty sure i have air in the lines though. didnt have a second person there to bleed them. Gravity bleeding wasnt really working
