Braking issue : Hard ABS feeling to normal braking when under heavy throttle
MrOneEyedBoh
So this has happened to me about twice a week now. I dont know if its because I now know how to replicate it, or its a worsening problem. I posted this over at the ORG and people said its happened to them for years, but no one ever found the source of the problem... This is what happens:
When Im giving it pretty good fuel, say around 75% throttle ( think merging into a tight gap on the highway ) and then I have to go directly to hitting the brake, the pedal will almost feel like its in ABS mode ( as if I were sliding on ice )
You can kinda feel the vibration in the pedal but then it goes from that ( hard braking ) then fades into normal braking pedal feel..
Does anyone have any idea on why this happens? It only does it when Im on the pedal heavy, and then to the brake pedal. Other than that, its the normal brake feeling all day during normal acceleration/driving.
happens to me all the time. just let of the brake and reapply.
i imagine there is slight wheelspin and the speed sensors are all talking to each other and then go into cardiac arrest when the brakes come on hard and slow the wheels down at slightly different speeds (traction, road surface comes into play)
...but i have no idea LOL
MrOneEyedBoh
haha There is a TSB for grabbing brakes/pedal kickback ( similar to ABS a little, no? ) It says to install a Magnefine filter inline for the hydroboost. Im going to flush the Hydroboost and install the filter. Filter number: M010CB
Then I'll use my Motive brake bleeder and flush the brakes.
ODAWG714
Orange*County, CA
Who's tune are you running? Just curious?
Anywho mine were doing the same thing. I even spoke to Greg at mpd about it. Replaced my rotors and pads and it fixed the issue. There's a place by my house that had rotors n pads for pretty cheap. Rotorworks.com
MrOneEyedBoh
Mine did it three times in one day yesterday. I'm running Gearhead tunes.
I don't think they are pad/rotor related, could be though. I don't see how unless they are below specs. I just had the tires off and checked the pads, they all looked fine
every superduty i have ever been in does it, gas or diesel
Mdub707
Mohawk NY
Mine has always done it and it's obviously more noticeable on the higher power tunes. I've had three sets of rotors/pads/calipers on the front/rear of my truck and it's done it for every set.
Josh@DirtyDiesels
PA
Mine does it too. I thought with mine it could be caused by the locker locking/unlocking when getting into the throttle and then coming to a stop... sometimes it does it, sometimes it doesn't
cfdeng7
CT
Every Superduty I've driven has done that after a high rpm run. Pretty sure it has to do with the power steering pump not being happy at 3500+ rpm
Sent from my SCH-I535 using Tapatalk 4
Dave
Mines done it too. I think its the ABS having a seizure LOL
Mdub707
Mohawk NY
Mine will also do it if I drive over a set of really rough bumps on the road too, no heavy throttle needed. I'm guessing a wheel or two is temporarily leaving the ground over the bumps and causing it. It basically wont go away until I let off the brakes and reapply.
Josh@DirtyDiesels
PA
I think a wheel coming off the ground trips it too. I know with my locker if I am say, pulling out while making a turn over a bumpy road my truck freaks out because a wheel is coming off the ground. It ***s with the brakes and sometimes will even shift funky when this happens. Makes the truck jump and tire chirp. It's pretty violent lol
