Bricked SCT x3!
6.0bomber
Wisconsin
So yesterday i tried to update my SCT x3, it said that the software installed properly, however when i plug my tuner into my OBDII in the truck, the screen will flash blue once and then act as if its turned off. When i plug it into the computer now, the screen lights up blue but doesn't do anything, nothing appears on the screen, just blank and blue. If anyone could help that would be great, i hear that the new updates bricked a lot of x3's and unfortunately before the update i set my truck back to stock, and now my truck is stuck on stock and i want to rip my hair out when i drive it!!!! :biggun:
GearHeadSales
Call SCT before you send it in, may just have to manually install the firmware. Also have seen it where the contrast gets changed after an update, they can tell you the correct sequence of buttons to press to change that.
