Built 7.3
fishing@fords
For sale: built 7.3 powerstroke.
.20 over coated and bowl worked Pistons.
Crower rods
WOP girdle with ARP main studs.
DI cam with welded gear
H11 head studs
Chromoly pushrods
Heavier valve springs (I forget which ones exactly)
Fire ringed heads
Bullet intake plenums
Half filled block
Roughly 10,000 miles since build
$5000.00 pickup only. I will drive 200 miles your way for full asking price.
Located in Clarksville TN
Engine in currently still in the truck. I will have pics when I pull it next weekend.
fishing@fords
I bought the engine already built. I believe WOP did most of the machine work and the builder put it together himself.
psduser1
on the road
Why are you selling?
What kind of power level did you run it at-injectors and turbo?
Any issues?
fishing@fords
I am selling so I can return the truck to stock and sell it. Don't have time for a project anymore. Never made it on the dyno with the last setup. Had 400/400s with large compounds. I hit 624 to the wheels with the previous setup (300/200s and 71mm single).
Never had any issues with the engine.
00xj74
Do you have documentation for the build? Does the engine come with an HPOP or turbo setup? I'm very interested.
00xj74
ok thanks. Does it come complete otherwise? If your sale falls through let me know as I'd come pick it up from you.
fishing@fords
Complete longblock; no injector harnesses, hpop, or water pump.
I'll let you if the current deal falls through.
